"____ is damaged and can't be opened."
Ok, so, I have 2 imacs. 1 is a 2009, the logic board crapped out. I have a refurbished 2012 in which the hd just crapped out. so i took the 2009 hd and put it in the 2012. got it back up and running, internet recovery, updated the os back to catalina. im currently at 10.15.7 with no updates possible via the app store.
thus far, i have had to replace the question mark items in my dock with the corresponding app from finder/applications by just dragging and deleting the ?.
then i went to download malwarebytes, and a jpg. whenever i try to open them, i get a popup stating: "____ is damaged and can't be opened."
normally, i use chrome, but was thinking perhaps it's a browser issue. safari will not open at all and sends error reports to apple, even from the applications folder.
in my gatekeeper, it also doesnt have the "anywhere" option, i had to terminal it in, but it disappears after restarting.
i've been googling and googling trying to find a solution that works, and to no avail. i have read, reinstalling the os doesnt work. ive tried other terminal codes, they dont work. ive run utilities/repair (first aid) and it doesnt work. ive run ccleaner. i also have a report via etrecheck.
i had figured i could just upgrade the os again to big sur and perhaps it would be fixed, but that update is not available, according to the app store.
please advise, cuz i dont know what else to do. i was running catalina before my hd went to crap and it was just fine. i shouldnt have to terminal anything or try to get a workaround, it should just work.
thanks in advance.
Esta é uma boa pergunta?
4 comentários
@danj what about this, sir: iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
por sean_gizzle
but not the 250gb, im planning the 1tb. not sure what i'll need a usb cord for...will have to look for the install instructions for this too.
por sean_gizzle
@seangworld - That works as well. The cord is for the case so you can place the SSD in the case and then plug it into your system to prep up! First Formating the drive with GUID and a jounaled file system then running the OS installer from your current drive to install a fresh copy of the OS and then using Migration assistant copy over your user accounts, apps and your user data (if you have anything on the drive) to the SSD.
por Dan
nothing on this 2009 drive is worth keeping. a fresh install from internet recovery would suffice? then upgrade from there? im guessing i cant do all the upgrading after installing the ssd and closing it up? that was the plan anyway...
por sean_gizzle
