Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
iPhone 8 Plus boot loop
Just replaced my iPhone 8 Plus back housing, since the old one has crack. Now that the phone is fully assembled, it boot loops. Apple logo starts to appear then turns off and then turns on again (looping). I tried to reseat all of the cables that connects to the phone, but still the same issue.
  • What troubleshooting steps can I try to fix it?
  • What could I have damaged if it keeps boot looping?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
This was the issue. Replaced this part and now the iPhone is fixed!
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
First step is to try restoring it via iTunes or 3U Tools.
If that doesn't work, maybe you slightly bent a board when removing it. In that case you need to visit some micro-soldering workshop to give you a full diagnose.
Pontuação 1
Adicionar a sua resposta
Myles Earvin Uy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 264
