Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
iPhone 5c has no power.
Hello! I am having delivered a iphone 5c that has no power. Why would this happen? I pretty sure it would be the battery or the screen. Is the iphone able to turn on without a battery or show signs that the battery is dead? Like how with one of my previous iphones it turned on with me just plugging it in and it was because the battery was dead. Does the iphone 5c do this as well? What are the other reasons this would happen other than the ones I listed? Or do I know for sure it's one of those things. I do not have the phone yet so I do not know to many things about the phone. The phone has some cracks in it, so it has been dropped before. EDIT The phone has some damage on the inside that I can see. Can one of these cause the no power issue?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Note: I realized that the first one is a damaged speaker
por
Adicionar um comentário
2 respostas
Solução escolhida
Screen was not the issue or the battery, not even the charge port. I plugged it in for a while and performed a hard reset and it turned on. Yes the screen has some issues but that was not the reason for the issue. I should've tried that from the beginning.
Esta resposta foi útil?
Pontuação 0
It could be the charging port has shorted I would recommend plugging it in when you receive it though as occasionally these sorts of problems fix themsleves
Pontuação 0
1 comentário:
about the battery on screen, I do believe that 5c's have this functionality so if nothing comes up It could just be the screen, I am not sure if the 5c has it but check to see if there are any blinking lights when you plug it in as this may indicate the charging port and device are still operational while the screen is not
por
Adicionar a sua resposta
Connor Steffenhagen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 68
