Ir para o conteúdo principal
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
NDC001 error code after screen change
Hello, I bought a 2017 MacBook Pro A1708 without Touch Bar with a broken screen. After changing the screen and doing a diagnostic I have the error code NCD001 which means the camera is not connected and therefore not working (FaceTime and photobooth). After performing the following operations: SMC, NVRAM, it still does not work. Has anyone had the same problem as me and if there is a solution I'm in! Thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hey did you ever get it figured out?
Esta resposta foi útil?
Pontuação 0
1 comentário:
No, I didn't found the solution
por
i’ve same problem too!
Pontuação 0
1 comentário:
wonder if anyone managed to figure it out. Im thinking it might be the flex cable that was damaged?
por
Adicionar a sua resposta
Noémie THOMASSET será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 542
