Ir para o conteúdo principal
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
134 Perguntas Visualizar todos
How to make external display active with dead internal display
I got in an a liquid damaged MBP. The internal display is not working. An external display does work but all it’s showing is the users desktop image. I need to make it the active screen so I can get into Terminal to turn off the auto-boot. I’ve forgotten how to do it. Also any hints on what to look for on the liquid damage would help. Thanks. @danj
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@mayer - Did you close the lid?
Using an external keyboard and mouse you should gain access to the primary display window after you close the lid.
Esta resposta foi útil?
Pontuação 2
3 comentários:
@danj That works, Thanks. Any idea of what to look for as to the failure of the internal display?
por
@mayer - Likely a blown T-CON board. A common issue in this series as they run too hot!
por
The kid woke up and realized it was covered under his AppleCare after I cleaned it. Did do a Time Machine backup and restore his data onto a new MBP.
por
Adicionar a sua resposta
mayer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 110
