Display problems after replacing HD
Hi,
After following the DIY for the HD replacement wich went with no problems, i got a faulty display.
Even before i closed the computer, i turned it on and everything was ok.
After i completed the essembly, i turned it on and the display was like an old tv with bad reception and interference. Also, it has 2 vertical lines more os less in the middle of the screen.
Also the external display port works fine.
Let me tell you that i was very carefull handling the display during the whole process, so i can´t really understand how this could have happened!
I opened the computer again and checked all the cables and it is the same.
Can this be a problem with the inverter or the lvds cable?
Has anyone had a similar problem ?
regards
Esta é uma boa pergunta?
Hey! I have the same problem right now. Have you found any solution?
por tporczio
NVRAM Reset helped!
por tporczio
