Can you fix Marshall tufton to?
When i plug in the power cord/ turn on volume, the speaker is not responding anymore.. can you guys fix this?
Esta é uma boa pergunta?
Hallo heren , als je zoekt op Marshall Stanmore , vind je wel enige service info / schema’s van de voeding. dit is een grotere uitvoering dan de Kilburn / Acton , maar in principe zijn de voedingen (PSU) gelijk van opbouw.
ik kan u wel de gegevens opsturen , mail mij maar, pe1rfe@outlook.com.
met vriendelijke groeten,
Jan Hoeve, pe1rfe
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 553
1 comentário
It's difficult to know exactly what is going on. Maybe as a first step is to open the speaker and check for loose connections and do a general inspection to check if anything looks off (blown components, burn marks, corrosion,...). It would help if you take some pictures of the speaker once you've opened it, you can edit your post for that.
por Bram Driesen
