Ir para o conteúdo principal
The Motorola Moto Z2 Force was released in July 2017—with the model number XT1789. The Moto Z2 Force is an android based mobile phone that updates the pre-existing Moto Z2 Play phone.
16 Perguntas Visualizar todos
Does the screen replacement in the aricle fix the digitizer issue?
According to a repair shop my Motoz2 force screen frame separated which also caused the digitizer to mess up. So my question is simply if this artice resolves that issue or do I need to buy a digitizer replacement part and look for further help?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
what article are you refering to??
por
Adicionar um comentário
1 resposta
I assume you’re referencing the Ifixit screen replacement guide. Normally a display assembly contains everything, being the front glass panel, LCD display and the digitiser to register your touch. The repair shop might have been trying to only fix the broken glass panel (if you LCD & Digitiser were okay) but came to the conclusion that also the digitiser is broken.
So indeed, if you are able to source a complete display assembly, the digitiser issue will be fixed.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Anil Ajani será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 56
