Ir para o conteúdo principal
Trying to read pcb
is this tolerance or what?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This particular guy is a weird one. There’s actually not a resistor in that position, it’s a filter. On the other hand—this filter doesn’t go bad. What makes you looking at battery_swi line?
Esta resposta foi útil?
Pontuação 0
2 comentários:
I don’t think he has a problem with any device. He is trying to understand what symbols and abbreviations mean on schematic diagrams.
por
Pergunta mais útil
Yes this is the tolerance of the resistor. They usually have a tolerance of 1, 2, 5, 10 and 20 percent. These values are to indicate how much the component can vary from it’s from its nominal value.
Pontuação 2
2 comentários:
@imicrosoldering
Thank u too much
Can u tell me what is meant by MF
por
@seif_mohamed I will post this on your previous question about MF
por
Adicionar a sua resposta
Seifmohamed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Ao todo: 221
