Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
iPhone in boot loop when charger connected after screen replacement
I replaced my screen for an iPhone 8 that was badly damaged and I don’t get anything when I try to power it on. When I connect a lightning cable I just get a boot loop. I have already tried to proximity sensor and disconnected the selfie camera with still no luck. Any ideas?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Hi,
any news?
I had the same issue.
Best, Mauro
por
Got the same issue here!
por
Adicionar um comentário
2 respostas
Solução escolhida
This will be a battery problem.
·         Replace the battery.
·         Check the battery connector on the logic board.
·         Make sure no components have been nudged around the battery connector.
·         Try putting some force on the connector when booting.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@imicrosoldering I had the same problem and I replaced both the screen and the battery.
Any others idea?
por
Check this forum. I know its for and iphone 6 but try these solutions.
Phone stuck on apple logo after screen replacement
Pontuação 0
Adicionar a sua resposta
chelsea223 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Ao todo: 631
