Ir para o conteúdo principal
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Perguntas Visualizar todos
How do I swap out my optical drive with an HDD?
So I want to swap out my optical drive with a 2TB HDD. I understand the hardware part but is there anything I have to do (software-wise) to orient the drives together? I have seen word of a problem that arises with this in the 15” MBP. Anything I have to look out for?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Ah! Dual drive configs are a bit tricky!
Frankly, What made sense years ago makes little sense today! Let me explain …
Back in early 2012 SSD’s were still very expensive and traditional HDD’s where limited to 512/750GB in size and larger 1 TB drives tended to be fragile. So if you needed deep storage you would put in two 750GB HDD’s. But these large drives where still very slow! Spinning iron alone was not fast! SSD’s where faster! But still very expensive. People who wanted a faster setup would take the optical drive out and put in a SATA II (3.0 Gb/s) 128GB SSD making it the boot drive holding the OS and the bare minimum of Apps leaving 1/3 of the drive unused so the OS and Apps have the needed free space (elbow room).
The HDD vendors saw this move and many people didn’t want to loose their optical drives (or may not even have one) WD first gen of hybrid drive was a true dual drive setup sharing the one SATA bay’s port sandwiching a small SSD onto the drive. This really was not very good. Seagate intro’ed a caching SSD design basically the SSD was not directly accessible the HDD’s drive controller would take note what blacks where the most active and place a copy onto the SSD. So every time that block was needed it would grab it from the SSD instead of the HDD. Any updates would go to the HDD block and the SSD block would be updated. WD also finally went this way but their implementation was not as good and late to the market.
Apple took note of this and finally created an OS level cache design called Fusion Drive. Unlike the SSHD hybrid drives which only used one SATA bay, Apple used two physical drives. Apple’s design also migrated from a dual SATA setup to a PCIe/AHCI and then to a PCIe/NVMe and as it was at the OS level Vs the drive controller it also offered file level caching Vs block. It still followed the same basic idea of using the SSD as a cache drive always reading it for a saved block or run of blocks and always writing to the HDD and then updating the SSD.
But things changed! SSD costs have dropped! SSD’s are now larger than HDD in smaller packages! Apple realized this was the direction and to be one step better worked hard on embedded flash storage instead of a discreet drive with its own controller. We saw that with the intro of the iMac Pro and then the Mac Pro using raw flash units which is then managed within a custom MUX controller chip. That allowed Apple to create a RAID style SSD design light years ahead of others!
But I’ve gone to far with the back history of storage… Whats important here is understanding where we are today.
Let’s get back to your question:
While you can install second drive in your system running a dual drive setup Installing MacBook Pro 15" Unibody Late 2011 Dual Hard Drive I would recommend you install a SSD in the optical drive and leave your HDD (spinning drive) in the HD bay. The reason is the optical bay does not have crash guard protection unlike the HD bay so banging system the drive could get damaged. While one can create a Fusion Drive config using a smaller SSD in the optical drive to improve the HDD’s performance. Apples original drive was only a SATA II (3.0 Gb/s) and the original SATA cable was also not rated to run at SATA III (6.0 Gb/s) data rate. You’ll need to upgrade the cable MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable following this guide MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable Replacement and yes I did point to the 2012 cable as its the better cable and you want to also follow this Your Hard Drive Cable Is A Ticking Time Bomb
To add to this the Optical bay has a messed up SATA port within the logic board design that will not boot up under SATA III (6.0 Gb/s) So you need a fixed speed SATA II SSD if you want it to be your boot drive. You are then limited to SATA II data rate for that drive.
It all boils down to a bit of a mess! I would forgo the dual drive setup and just go with a single SATA III SSD in the HD bay which offers your primary storage and if you really need more storage then use the optical bay with a SSD. Forget the HDD (spinning disks)!
To help put this into perspective Samsung just released its new 2.5” 870 EVO SSD Samsung’s new 870 Evo SSD brings faster speeds, lower prices a 4TB drive just a few years ago was over $1,000 today its $530 USD!! And a 1TB is $140. So why are we going with a dual drive any more?
Imagem de MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable
Produto
$19.99
Imagem de MacBook Pro 15" Unibody Late 2011 Hard Drive/IR Sensor Cable
Guia
Nível de dificuldade:
Moderada
30 minutes - 2 hours
Imagem de MacBook Pro 15" Unibody Late 2011 Dual Hard Drive
Guia
Moderada
1 hour
Esta resposta foi útil?
Pontuação 0
4 comentários:
Hey! Thank you for your quick response, Thanks to you, I now know so much more about storage drives. First, what is meant by the term RAID? I have herd it before. Second, I have a 500GB SSD in my HD space and I will upgrade the cable accordingly. Third, is there ANY way that I might be able to fit an HDD in the optical drive bay? Thanks in advance!
por
What is your current SSD Make & Model?
Sadly, you can't put the HDD into the Optical drive bay without putting the data on it at risk. Best to install a second SSD in that case.
You also have an issue with the Optical drive bays SATA port as it won't support SATA III drives which is about all you can find these days. You'll need a Mercury Electra 3G OWC as you need a fixed SATA II (3.0 Gb/s) drive.
Sorry RAID is not something you can do in your system. Here's a good writeup that explains things: (Almost) Everything You Need to Know About RAID
por
I have a Western Digital Blue 500GB 2.5'' SSD. So, if I place the SSD in the optical drive bay and the HDD in the HD bay, it would work properly?
por
@airmanquick308 - Sadly, no your WD SSD is a fixed SATA III (6.0 Gb/s) so it needs to say in the HD bay as its the only bay that it will work in properly.
Which gets us back to what ends up being the better setup just getting a bigger SSD for your system and get an external case to put your WD into so you can leverage it.
por
Adicionar a sua resposta
Kjartan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 53
