Ir para o conteúdo principal
Lançado em 3 de março de 2017, o Nintendo Switch é um computador de mão que pode ser jogado na TV ou em qualquer lugar.
20 Perguntas Visualizar todos
Joy-con stuck on nintendo switch and broken.
My Joy-con is broken and it is stuck on my Nintendo Switch… Is there any way to remove the remaining part of my Joy-con from the Switch?
Esta é uma boa pergunta?
Pontuação 6
8 comentários
My long distance boyfriend had this issue for at least 2 days, and he was a bit scared on how to fix it. This helped get those broken pieces off right away! Thank you, now we know just in case this happens again, since we do enjoy playing Minecraft every day
por
Ohh push from the back of the console down not in, got it now
por
Do you push it into the switch or away from it?
por
Which way do you push it?
por
This happened to me, the only thing I'm struggling with is putting the top back on...
por
Exibir mais 3 comentários
Adicionar um comentário
6 respostas
Solução escolhida
I’ve figured it out by myself, but in case if anyone’s having the same problem as me, I’m posting this by my self.
You can try pushing the red part of the image all the way, and it will probably detach.
Esta resposta foi útil?
Pontuação 24
16 comentários:
Thank you. This has been the only useful thing I have found for the same issue. All fixed now!
por
i tried it didn't work for me, is there any other ways
edit: i tried again a few more times and the remaining piece finally got out! thanks
por
I had this same problem so now m parents are gonna kill me but I saved my switch. :/
por
thank you so freaking much!!
por
THANK YOU SO MUCH!!! However… is there any way i can get the orange straps back into the joy con?? Or would i have to contact support for this… i have no expire with unscrewing joy cons and stuff D:
por
Exibir mais 11 comentários
i don’t have a red thing 😬😬 my parents r going to kill me…
Pontuação 2
4 comentários:
Oreo, when Yoon said "the red thing", he was talking about the part of the joycon still stuck on the console that he'd *circled in red* in his picture. Find that same spot on your joycon rail and press it and it should slide out. When your joycon is intact, that's the part the release button moves against when you press it.
por
ohhh my bad i the picture it looked like it was red 🫣 but i figured it out but now i gotta figure out how to get the controller back on
por
What red thing I don't see it
por
Yeah for but my controller broke but didn't leave anything on the Nintendo switch and it was on the Nintendo switch idk how but that's lucky
por
Dose this work for the right joy con as well? I have the same issue rn. Thank you in advance
Pontuação 1
2 comentários:
it works on both so yes
por
Bro, literally happened today. BLESS YOU mother F'er. Forever thankful 🙏
por
Thank you for this. Slid right out! Life saver! Lol
Pontuação 0
My switch fell and now the black controller broke and now there is yellow wires
Pontuação 0
1 comentário:
You beautiful life saver you
por
Hmmm idk but you might want to go to a repair shop for that🤨
Pontuação 0
Adicionar a sua resposta
Yoon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 45
Últimos 30 dias: 180
Duração total: 21,172
