Ir para o conteúdo principal
Phone wont switch back on after hard reset to fix black screen
My iPhone 6 was working fine up until yesterday which was when I noticed my screen kept freezing and glitching(.multicolored lines flickering on the screen )then I would simply press the power button once to switch it off the back on again and it would work fine again for a moment or two before freezing again so I hard reset it and the problem was fixed . However this morning when I woke up I turned on my phone to check the time and I could see the backlight was on but the screen was black and there were short grey horizontal lines along the bottom of the screen .I switched it off thinking I was still dreaming but it was the same when I checked it again .So I tried to hard reset it and now it wont switch back on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I think you need to replace your screen with a new one, but before order a new screen you can open up the iphone and check if when you reseat the flex connectors the screen work properly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
DesertStormer04 Gg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 19
