MacBook Pro 2015 13-inch, left shift key stuck after battery replacem
Good morning, We have successfully replaced the MacBook Pro 13-inch battery.
However, there was no problem at first, but after about a week after the replacement, the left shift key does not work.
If you just turn on the power, it is connected in safe mode. In the safe mode, the password to access the computer is also entered while the shift is pressed, so the connection is not possible. So, when booting, press the option -r key to connect normally. However, if you connect like this, you cannot use the left shift key on the computer. Maybe it's a motherboard problem?
In my opinion, I’m worried that the adhesive agent used to remove the battery is on the motherboard. Is there any way?
I would like to know which part of the main board is the left shift part.
Please help!
Esta é uma boa pergunta?
