Ir para o conteúdo principal
iPhone 11 turning off after screen replacement
I repaired an iPhone 11 it was a screen replacement and back glass replacement with the forward laser machine everything seemed to work fine but when the phone is on for a couple minutes the phone turns off and back on. After it randomly restarts it acts like normal until a couple minutes have passed it does it again. I’ve tried a different battery and even the original screen but it still does this. I’ve also disconnected the front speaker flex in case it was causing problems but it still does it. I put it into dfu mode and updated it successfully now its on a white screen that says attempting data recovery but it keeps turning off before it finishes any ideas on how to fix this power off problem.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
have you try updating the phone
por
Adicionar um comentário
3 respostas
Solução escolhida
In this case, the charging flex or the microphone/flashlight flex next to the camera might be damaged.
These contain sensors (prs0 and mic2) that cause the phone to restart after some time if no valid signal is received.
Esta resposta foi útil?
Pontuação 1
I had the same problem with a iPhone 11
tried everything
last resort is changing out the battery
Pontuação 0
If the screen was replaced without disconnecting the battery it will short circuit your phone therefore once that is done even a new battery will not fix it it's happen to me twice once when I paid for it to be fixed and second time I did it was trying to move to fast
Pontuação 0
4 comentários:
Any fox for this ??
por
Oh $@$* this happened to me. Does the iPhone eventually go out? I’m trying to transfer my data before i send it back to asurion?
por
How can you help me fix my
por
@ogevidence We're going to need more information if you want help.
Best suggestion is to start a new question and fill in the device field so we know what phone you have, then state exactly what the phone is doing or not doing, when it started and what you've tried to do to fix it.
por
Adicionar a sua resposta
Daniel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 40
Últimos 30 dias: 139
Duração total: 11,099
