Ir para o conteúdo principal
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Perguntas Visualizar todos
Why do I have horizontal color lines after touch screen replacement?
Hi all, could you please help me? I have horizontal color lines on original LCD after touch screen replacement. Home button and power button works correctly. Any advice please? Thank you so much in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Looks like damage to the LCD. You’ll probably have to replace it. iPad 6 tablets have a small amount of adhesive which holds the corners down where the screws are inserted. If you applied too much pressure beneath the LCD to pull it up, it could have damaged it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mt.turcan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 46
