Ir para o conteúdo principal
The T Flight Hotas 4 is a joystick controller manufactured by Thrustmaster in 2015 that is used for specific flight simulation games. Model number 4169083 is currently supported by PC and PlayStation 4.
Sourcing a replacement potentiometer for t flight hotas
Try as I might, I've not managed to source a replacement potentiometer for my hotas. Is anyone aware of a company that might sell these parts? Thrustmaster customer services were no help at all and as far as they're concerned I should chuck my beloved flight stick on the scrap heap
Esta é uma boa pergunta?
Pontuação 2
3 comentários:
I have a similar issue with the T.Flight Hotas X throttle potentiometer, tried cleaning original but no luck.
I’ve ordered a couple of pots that might do the job , I’ll post back here with details and part numbers if it works out.
If you have any details on the pot in question post them here and I’ll see if I can help.
por
did you find any potentiometer that worked?
por
None that were cost effective. I suspect that the answer below may have been the right one, but I'd thoroughly ruined the existing potentiometer by then!
por
Adicionar um comentário
1 resposta
This may help. Replacement pots for TM HOTAS. https://www.radwell.com/en-US/Buy/CH%20P...
Esta resposta foi útil?
Pontuação 0
1 comentário:
If you're having erratic yaw problems I found the fix for that. No parts needed. I just did this to mine and it works. https://imgur.com/gallery/ob06FmA
por
Adicionar a sua resposta
Joe Lewis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 32
Ao todo: 2,842
