Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
20 Perguntas Visualizar todos
Upgrading 27inch display iSight camera
Can I swap out an iSight 27” Cinema Display camera for a Thunderbolt HD one?
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
I’d love to do that as well, is there any news?
por
Adicionar um comentário
2 respostas
Given the amount of work and the risks I really don’t think its wise to even try. The difference is not that much to be beneficial, that’s assuming it would even work (I haven’t tried doing it).
I think you’ll find getting a clip on camera will be cheaper and offer even better performance!
Esta resposta foi útil?
Pontuação 0
Hi all, yes this is possible and quite easy. I’ve done it myself (installed the OEM FaceTime HD camera from a 27” Thunderbolt Display into a 27” Apple Cinema Display). Both displays are mechanically identical for the purposes of this tear down , and have the same opening and closing process. Both cameras use the same USB2 interface via a 5 pin flex cable. I bought a used camera from a Thunderbolt Display for a few dollars on eBay. And I followed the tear down process from iFixit to the point where I removed the camera from the Cinema Display, then installed the new camera with no modifications. They look identical, have the same connector and dimensions and attachments. I managed dust and installed the display panel and used suction cups to put the glass screen back in place.
Apple Thunderbolt Display Teardown
Follow Steps 1 to 6
Skip to step 16 for camera removal, dont remove the flex cable, just disconnect the camera
Install new camera with same screws
Steps 6 to 1 for reassembly
Following the steps above, I now have a Cinema Display that shows “Display iSight” for the installed camera (e.g., on Zoom camera settings) but returns a 1280x720 still and video which is an improvement of the 640x480 original. Interestingly device name seems to be a trait of the monitor it’s installed in. And performance seems fine. I have occasional single-frame blanking on the image itself, but I believe that’s a symptom of using it with a PC as I don’t get the same on a Mac.
To do this successfully, I bought the suction cup kit recommended in the teardown to take off the magnetically attached front glass, and used a driver kit to remove the display and connectors.
With these changes and attached to an Elgato Thunderbolt 3 Dock with a DP to MiniDP converter from Startech, my 27” LED Cinema Display is a great replacement for my Thunderbolt Display and has a longer life ahead of it (Display Port video, USB2 sound, camera & microphone supported broadly) vs the finicky TB displays
Pontuação 0
Adicionar a sua resposta
Eric será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 1,109
