Broke tiny bottom connector that holds the trackpad ribbon
I accidentally broke the tiny connector that holds the trackpad/keyboard ribbon in the bottom. Now my MacBook won’t powerup. I was trying to replace the trackpad ribbon. can you please advise what that part is called? and how I can fix/replace it? Your help will be greatly appreciated.
Update (12/31/2020)
Here is an image :
not sure if the image is visible. i am new to ifixit. here is an example: https://d3nevzfk7ii3be.cloudfront.net/ig...
The cable slides in and there is a small black connector that clamps down..
Esta é uma boa pergunta?
5 comentários
You can use kapton tape to hold the cable in place instead.
por Ryan
Thanks Ryan! Really appreciate your kind responses. My mac stopped booting up or charging after this broke up, is this normal? it didn't make sense to me.
por Its Me
No problem. That does seem odd.
Just to clarify only the ZIF Connector broke right? That's the flap that you flip up/down that holds the flex cable in place.
The ZIF connector shouldn't have any bearing on the Mac booting up as far as I know. Did you disconnect the battery before replacing the cable?
por Ryan
Yes that is what is broken. I didnt disconnect the battery.
por Its Me
Ryan, is there a way to revive my mac? I think i understand now what I messed up.
por Its Me
