Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
Game save randomly lost.
Hello. I’m having a weird issue with my Pokémon Yellow. The game save file randomly was lost and now refuses to save. I assumed the battery had croaked and opened it up to check it. The battery still has a 3V charge. It has been a while since this initially happened so idk if charge built back up again. Any thoughts?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
can consider replacing to new batteries.
many considerations, like heat cause battery chemistry to be unstable,
dry solders, causing intermittent bad contacts, which need to reflow or touch up with new solder.
por
Adicionar um comentário
1 resposta
who still uses the gameboy?!? whatever if you want it i think it is ethier it is how old the system is or it is the battery inside the game not the console.Idk why it refuses to save though :/
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Macalroy38 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 299
