How to remove plastic shaft cap of the 800CPXL?
I need to replace the security microswitch SP0011048 in my 800CPXL, and I’m not sure how to remove the plastic shaft cap that supports the die cast reamer. I was able to determine the switch was broken without removing the cap (and everything sitting half way inside), but clean removal of the old part & soldering of the new part would be so much easier if I could pull everything out of the housing… Replacement instructions where I bought the part simply say “disassemble the juicer”, and I think the cap is just pressure fitted on top of the shaft, but it’s not budging when trying to pull or pry it off & I don’t want to break it.
Esta é uma boa pergunta?
