Ir para o conteúdo principal
Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
210 Perguntas Visualizar todos
Why is MacBook taking too long to charge?
My new macbook is taking too long to charge (taking about 18-20 hours to charge fully). The cycle counts for this macbook are just 4. Moreover, this macbook is new although but I have started using it after few months. Furthermore, I have even tried resetting SMC. But still facing this issue. Besides that, I have also installed coconutBattery.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Who's charger are you using (Apple or other) and what is its wattage. In addition what is the USB-C cable the Apple unit that came with the charger or something else.
por
@danj its the charger that was present with Apple packing. Its a 96 Watt USB-C power adapter
por
Adicionar um comentário
1 resposta
Solução escolhida
You’ll need to try a second charger & USB-C cable to be sure, I’m suspecting the charger has a problem. I would visit an Apple Store or Apple dealer to see what their charger does. Clearly the 7.7 Watts is low.
You might want to invest in a USB-C power meter Type-C USB Power Meter
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Taha Asif Siddiqui será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 178
