Where can I get an antenna converter cable?
My new charging port did not come with an antenna converter cable and my old one is broke. Where can I get a new one from?
Esta é uma boa pergunta?
Your best bet would be to pull from a donor port. You are talking about the small black antenna soldered to the Charge port correct?
if you were a business you could purchase it from the following area. But, It will at least give you proper naming to buy on ebay. https://www.mobilesentrix.com/wi-fi-ante...
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 244
No, the small flex cable the connects the bluetooth/ wifi antenna to the charging port.
por cd70451
Ok you talking about the Flex that runs along the Flex Charge Port. Let me see if I can find one
por Shawn Blair
por Shawn Blair
Thank You. I found one on ebay. Here is what I was talking about. https://www.ebay.com/itm/Dock-Connector-...
por cd70451
