Why is the analog stick jittery, erratic, or jumpy?
I purchased 3 of these controllers and all 3 have trouble with a jittery right analog stick
Esta é uma boa pergunta?
If you are using a tool like this https://gamepad-tester.com/ and notice that one of the joysticks/analog sticks are moving erratically, here is what I did to solve the problem:
Esta resposta foi útil?
I tried this on my PDP Xbox One controller that had a jittery left analog stick (the potentiometer for up/down would jitter down erratically with the slightest pressure in the up direction). At first it didn't work, but then I slightly cracked open the white cover of the potentiometer from the top by pressing in the little clips on its sides and using my fingernail to crack it open from the top so the wires were showing, then wash with automotive degreaser, blow with compressed air = jitter completely fixed!
Últimas 24 horas: 9
Últimos 7 dias: 76
Últimos 30 dias: 327
Duração total: 12,919
