Ir para o conteúdo principal
Third generation of the Fitbit Charge fitness tracker series.
19 Perguntas Visualizar todos
Fitbit Charge 3 charging pinout?
I was looking for the pinout earlier and nobody on the internet had the answer...
I ended up buying a charger clip and promised myself to post the pinout to help anyone who needs to charge it without the clip.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
1 resposta
Pergunta mais útil
From left to right:
  • +5V
  • not in use
  • GND
Esta resposta foi útil?
Pontuação 8
3 comentários:
Appears that this info is also correct for the Fitbit Charge 4 as well.
por
I brought Fitbit charge 3 band for less than $1 at scrap store. Thank you for the information, i needed it finally, now I will hack into it
And add new battery and charge without the clip...
por
Also worked on a Fitbit Inspire 2, which looks similar on the underside. 5V (red) on the left contact, GND (black) on the right, when oriented like the photo.
por
Adicionar a sua resposta
io nut será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 38
Ao todo: 3,636
