Ir para o conteúdo principal
The Xiaomi Redmi Note 8 is a mid-range smartphone by Xiaomi released October 2019. It has a 6.3" IPS LCD display, a 48 MP main camera, a rear-mounted fingerprint sensor, a 4000 mAh battery, and runs on a Snapdragon 665.
My phone thinks the down volume button is pressed
I own a xiaomi red mi note 8.
I was listening to music normal and it started lowering the volume by itself. I tried to get the volume higher a few times (pressing the up volume button or using the screen) but it kept going all the way down.
So i turned it off and cleaned it a little bit just in case something was bothering the button from the outside, or if the system was stuck. Then when I opened it and it still thought that the down button was pressed so it sent me to fast boot. Somehow I managed to boot it properly and now it seems to be okay, but i think it will happen again.
Is it a hardware or a software error? if there’s nothing I can do about it I might need to buy a new one.
Esta é uma boa pergunta?
Pontuação 14
6 comentários
This is what's happening to my phone now. It's Redmi note 7 btw. :/
I start to think that I need to switch to another brand. Xiaomi sucks :’(
por
It’s the second time this happens to me. The first it just went away in a matter of hours but now it’s really irritating me. It won’t go away. The Google Assistant fix doesn’t work for me either, ugh!!!! I can’t live without music and videos so this is annoying
por
I have the same problem holding the volume down button even though I haven't touched it
My phone is Black Shark 4
por
It works! Thanks for saving me from all the hassles. I'm dumbfounded
por
Change the volume flex and try.
por
Exibir mais 1 comentário
Adicionar um comentário
9 respostas
Solução escolhida
I know it's late for answer but i was having the same issue and i hit sound up/down button to table 2-3 times and it fixed :D
Esta resposta foi útil?
Pontuação 122
127 comentários:
No way that worked for me too lol. Made an Account Just to thank you. :)
por
Lol, the same . Why does it work xd??
por
wow mate, thanks for your answer, it literally solved the problem
por
Man, it really worked. I almost gave up and buy another phone. Thanks a lot
por
Yeah, that worked for me too. Even my phone entered fast boot mode multiple times and the volume went all the way down to zero on its own.
I thought it was a software bug and soon had made my mind to install custom rom or so. Hitting the button (gently) literally solved the problem! Thanks!
por
Exibir mais 122 comentários
For people who has this issue and hitting table doesn't work, i found an app named 'buttons remapper & combinatin' by 'Irishin'. You should download it, then give permission and then click + button in app, choose the button with the problem for me it is 'volume +', choose 'do nothing' for the action and enable 'block system action'. From now on my volume up button is not sensing anything. For increasing volume , i will use volume down button to see the volume window on screen then will use touchscreen to turn the volume on.
Pontuação 13
6 comentários:
Hey there 👋
Made an account just to say — Thank you. This bug has been following me for nearly a year now. No idea why it started, but honestly, this little mf annoyed me quite a lot, and as I can see, not only me 👀
Anyways, glad I haven't stopped searching for a solution 🤝
por
Thank you so much for this solution! Banged the volume button several times already, but this one you suggested is what worked!
Just made an account, too to let you know how grateful I am! Thank you so much!
por
This works best for me so far, thank you so much. It was suddenly not working (said remapper is malfunctioning) but I reinstalled it and works again. I've tried to solve this by pressing the middle space between two buttons and didn't work but this app did!
por
Thank you so much
por
Valeuuu Salvou minha vida.
Já estava desesperado!
por
I had the same thing. Just smash the volume button it 3 times at the table and it will be fixed
Pontuação 10
8 comentários:
Worked perfectly
por
Perfect working
por
I cannot believe that it worked. Thanks a lot.
por
NO Way it worked
por
its perfect working
por
Exibir mais 3 comentários
I had the problem there i smacked the phone on my bed and i was hitting my phone without any reason then i found it was a software problem. After knowing it i started searching for a genuine solution but i didn’t find any but after a lot of reaserch i just solved my problem by reboot.
Redmi volume button problem solution
Hope this will help you also
Pontuação 5
2 comentários:
Fixed by hitting lightly on bed ..great
por
I had the same thought as you, but if you try rebooting it while the volume down button is pressed (stuck), you'll get stuck in fastboot mode. I fixed it by hitting the volume down button a couple of times
por
I put a cloth on my finger and rubbed it on the volume buttons making them click again and again it fixed the problem
Pontuação 1
1 comentário:
I have a Xiaomi note 8 pro I had a problem my volume up button was always on, I searched and I found a solution I wiped the headphone socket bottom of my phone with a cotton swab and problem solved
If this worked for u too like this
por
OMG boys, smashing it works. WTF! :D :D :D
Pontuação 1
I got a xiaomi redmi note 8. And today I experienced the same thing and it started when I was playing league of legends: wild rift and it becomes a hindrance in my game as it blocks the buttons I use to play the game. If you want a visualization; the volume always appear in the screen, every second so it doesn't go away. I tried restarting the device but the options to "airplane mode";"silent mode";"restart";"shutdown" don't appear. So, I long press and the device shuts down. Then when I try to open it go to Fast Boot. I tried doing what Mustafa said and in addition tried to clean the earphone slot with cotton buds with 99% alcohol. After that my phone goes back to normal. (I already have pried open the back of my device to try to fix the buttons itself but don't know how to get into the buttons itself.) Hope this helps the others before they pry open their device.
Pontuação 0
Volum botten is not working
Pontuação 0
My phone not work vibra this coming call
Pontuação 0
Adicionar a sua resposta
whyyy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 29
Últimos 7 dias: 210
Últimos 30 dias: 1,138
Ao todo: 95,285
