Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Faster way to remove loudspeaker
The loudspeakers of my iPhone 4 have very low sound. I want to replace the loudspeaker, I am looking at the ifixit guide and I am wondering if there is a faster way.
If I remove only the docking connector, and two screws holding the enclosure, will that be enough? Is it necessary to remove the logic board?
I have never disassembled the iPhone 4 yet and I was wondering if someone has tried this shortcut, or it is completely impossible.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I did it my way with total success :)
The replacement was much faster and easier than removing the logic board and I did not feel I put any pressure on the board.
Thanks for your help.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You can slip it out that way you described. Take off the screws for at least the lower part of the logic board, that way it will give you more "wiggle room." It does put a little more stress on the logic board and you are prone to breaking off the metal prongs on the antenna. That's why we don't recommend doing it that way on our guide. But it can be done.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Scott, I will try and let you know if it worked or broke something in the process.
por
Adicionar a sua resposta
lantzero será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 797
