Asus G751JY Laptop won't power on (no lights)
Model: G751JY-T7094H
Hi,
The laptop stopped suddenly while in use and since I couldn’t start it again. No lights on even when plugged in. I tested the power supply and the multimeter indicated 19.5v as expected. I also tested the battery (not sure though if it is meaningful) and the expected voltage was what I read. I replaced the CMOS battery (I don’t know if this was necessary).
I need some guidance about what to replace. Which tests can I perform to identify the culprit? A new motherboard is pricy. My battery is old (5 years with daily usage), can a dead battery prevent the lights from turning on and the laptop too? Is it the DC connector? How can I know?
I hope someone can help.
Esta é uma boa pergunta?
