Ir para o conteúdo principal
Released in 2018, the Dell Latitude 7490 is a 14-inch laptop released for the business market. It uses a 7th- or 8th-generation Intel Core processor and most components are replaceable.
Why do some keys click harder than others?
On my dell latitude 7490 I encounter a slite problem. Som keys are nearly silent en some have a definitive “click” sound. The keys with the hardest click sound are the delete key and shift lock key
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You can remove the bottom cover and check that your battery isn’t swollen or bulging. I have this exact model and when my battery swelled up, it caused some keys to have louder clicks. Once I replaced the battery with a new one, it was resolved. I’d also suggest blowing out the keys with a can of compressed air in case there’s something stuck under the key.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
AVD será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 381
