Ir para o conteúdo principal
Repair and disassembly information for the fourth-gen iPad Pro 12.9". Announced and released in March of 2020. Model A2229.
Usb c to 3.5mm with microphone
What is the solution to using an Astro A10 gaming headset with attached microphone on the newer ipad with no headphone jack? I've seen dongle usb c to 3.5mm adaptors for sale but they only support audio not microphone input/output also.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
The iPad Pro 4th gen offers a full USB-C interface which does offer bi-directional input/output.
But you need to re-think your expectations! You’ll need a bit more gear to get this to work via a wired connection to get the input to also work through the headset.
Most people just use a good Bluetooth headset to get around this limitation. But, are you sure you want to use this iPad for gaming?? It’s not really designed to support long duration game play.
Esta resposta foi útil?
Pontuação 1
I can confirm that the Apple original USB C to (3.5mm) Headphone adaptor DOES work with an external microphone. I bought a Belkin adapter that does not work. The Apple adapter apparently includes TRRS compatibility. The Belkin I bought does not.
Pontuação 1
Adicionar a sua resposta
Litman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 991
