Ir para o conteúdo principal
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Phone not turning on at all
So, I got this phone about 1 year ago from my brother(it was his old phone), and I got it repaired about 2-3 weeks ago because the charging port was bent. I charged the phone at the same level as the charger most of the time,and now it won’t respond to the charger at all. I turned it off and did a factory reset, deleted cache and everything. Now when I plug it in it just instantly shows the Samsung Galaxy Note 4 writing and gets stuck there. I can’t do a factory reset or anything else either, and when I take the charger out its just a black screen.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If the phone immediately shuts off after you unplug it from the charger it probably needs a new battery.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
XavierIsVibing será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 93
