Ir para o conteúdo principal
Released November 2020, the PS5 console features vastly upgraded visuals and an innovative new Dualsense controller. The space-age black-and-white color scheme is a noticeable departure from PlayStation designs of the past.
189 Perguntas Visualizar todos
How thick are the thermal pads on memory ICs?
Would like to know so I know what thickness pads to order.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Is there any reason you would want to replace them? I know there was a video showing how hot the ram gets but we haven’t seen many (if any) failures from this so far.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I would assume their reason would be the same as mine: General maintenance, and life extention of their console. Better not to wait until it does cause a problem before maintaining it.
por
Between 0.7-1.5mm.
I'd opt for trying which ever is the thickest in that range that can be fitted perfectly.
Pontuação 0
Adicionar a sua resposta
Lan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 432
