Ir para o conteúdo principal
O Asus Tuf Gaming FX505GT é um notebook de 15,6 polegadas com um processador Intel Core i5 9300H e uma GeForce GTX 1650. Ele possui o Windows 10 e foi fabricado pela Asus em 2018.
Not connecting to monitor
Hi .. can someone help lol
Imagem
I normally connect my laptop to the TV via HDMI and a few weeks back after an update , it stopped doing that and would only do it through a wireless connection … I then got a samsung monitor for use with my xbox and I tried to connect laptop to that using HDMI (monitor does have DVI port) and it still isnt having it but in the settings , the monitor is listed so the laptop is recognising it somewhere … Any ideas without taking laptop back before the update that ASUS have advised me to do … ? Thanks
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Have you tried using different cables? I would also double check for NVidia driver updates for your graphics card. It's plausible that the update caused some OS corruption, or exacerbated existing corruption, but that is a more complex fix if that's the case.
por Compartilhar
Thanks for your reply ... I have tried different cables .. apart from the DVI cable as I havent got one .. just ordered one so will try that then I will have a look at the graphics updates and I dont even wanna think about corruption haha !
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
@listersister12
Hi Jen,
An update of what? A driver? Just roll it back with Device Manager, if a driver. It worked before the drive update so that is the most probable cause. That should fix it.
It is unlikely, but not impossible, that it is the cable, especially if it worked before.
I guess you have checked that the Samsung was set to the correct input?
Still not working? Corruption is no big problem so you can think about it. First just uninstall the Graphics driver, reboot and then let Windows rediscover it. If you really think there is still a prfoblem then use Display Driver Uninstaller or DDU:
https://www.majorgeeks.com/files/details...
which completely removes all traces of the driver. Re-install.
Let us know how it goes.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi Mike ...
The update was a few things .. I just set them going from the windows update page on the control settings .. I didnt actually take much notice of what was being updated to be honest - it was one of those days and I just set it away doing its own thing without actually taking much notice !
Defo not the cable as I have tried so many and monitor is still not picking up laptop and yeah the monitor is in correct input ...
I will have a look at the device manager thing now and if that doesnt do it I will do the display driver uninstaller and go from there ..
Thank you for your reply
por Compartilhar
Maybe graphic card has an application to config external monitor. Have you checked it?
Pontuação 0
Adicionar a sua resposta
Jen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 4,371
