Ir para o conteúdo principal
Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
468 Perguntas Visualizar todos
**VERY IMPORTANT** It’s crazy but Siri pop up kills headphones mic :(
Hello everybody!
I’d like to share a crazy issue that happened for me and many users (as I checked web) after recent iOS update!
And there’s a possibility it happens for you too...
What is the problem?!
After connecting a headphone (Apple or other brands) a “Siri pop up” appears on screen and you will lose your headphone microphone!
I tried to make sure it’s because of Siri, so I opened “Voice Memos” started a recording and then I connected the headphone to the iPhone, it was working until the Siri pop up appeared (a few seconds) and after that the microphone was lost!
I tried what I did several times but the results were the same. I had microphone for a few seconds and just before Siri pop up appears.
When it happens doesn’t matter how you use your phone, if you’d like to call someone or talk with your friends in online games or maybe order Siri to do something...
Your headphones microphone won’t work! It’s Dead!
It won’t fix by change settings or turning off “Siri” because “Voice Assistant” will appear instead!
At the the end it makes headphones unusable...
I searched web and Mobile and Apple communities for a fix, many users have the same problems and nobody knows what to do!
PLEAZZZZZZZ HELPPPPPPP or if you have access to Apple tell them the problem!
Update (11/30/2020)
Hello
I have an iPhone XR.
It’s OK and there’s no problem with Bluetooth.
But I have to use headphones with cable because I need the voice without delay.
It happens just with cable no matter which brand I use.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Which model of iPhone do you have?
What happens when you use a Bluetooth headset?
por
Did you try a second lightning to mini jack adapter?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I have seen this issue with a number of iphones. Its typically a problem that results from a non apple set of headphones, a bad connection on the headphones. i.e. there is garbage in the headphone jack that is causing the headphones not to fully seat in the jack.
I would attempt a different apple headphone set and if this still occurs attempt to clean the headphone jack of any debris and retry.
Also you can turn the Voice assistant off as well following the directions below.
Follow these steps:
  1. On an iPhone X or later, go to Settings > Accessibility, then tap Side Button. On an iPhone 8 or earlier, go to Settings > Accessibility, then tap Home Button.
  2. Under Press and Hold to Speak, select one of these options:
    • Siri: Siri will respond when you press and hold the Home button.
    • Classic Voice Control: Classic Voice Control will respond when you press and hold the Home button. This will also turn off Siri.
    • Off: There will be no response when you press and hold the Home button.
The press and hold setting applies only to the Side or Home button. If you're using a headset, and it unexpectedly activates Siri or Classic Voice Control, make sure that your headset is fully inserted into the device.
If you have a loose or poor headset connection, frayed cables, or moisture on the connector or remote, it might unexpectedly activate Siri or Classic Voice Control. If the issue persists, try using a different headset.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you for your helpful comment!
por
You are most welcome my friend. Cheers!!
por
Adicionar a sua resposta
Mahdi Izadi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Duração total: 2,217
