Ir para o conteúdo principal
The Mozart Magic Cube, Serial Number: 3528203101, Model Number 03101, is the 2008-2012 version of the musical baby toy by Munchkin Inc.
5 Perguntas Visualizar todos
How to remove a stuck battery cartridge
After removing the battery cover, the cartridge is stuck in the toy, no matter how hard I pull with my fingers.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
(This is with the newer model — not the one depicted in the image.) I could not pull the battery cartridge out with my fingers. I wound up using a pair of vise-grip pliers to grasp the cartridge “handle” — with the pliers gripping the short ends of the handle. Just be careful to adjust the pliers so they don’t crack the handle — use just enough force.
By the way, I called Munchkin first, and they suggested using a flat-head screwdriver around the edges — didn’t work. However, the support rep said if that didn’t work, they would provide a free one-time courtesy replacement.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
David Eisner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 82
Últimos 30 dias: 311
Duração total: 6,864
