Ir para o conteúdo principal
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554 Perguntas Visualizar todos
Craftsman T110 Brand New Clicks but won't crank
I have a brand new Crasftman 42” T110 that has a manufacture date of 06/2020. It has run perfectly so far, but this past weekend I changed the oil and fired it up. Since I had it out and running already I decided to mulch some leaves. After passing over the leaves it clogged the blade and killed the mower. I backed it up raised the deck and fired it up. The blade clogged again even at the higher setting and then when I went to start it again all it does is make a loud click coming from the deck area. There is no crank in the engine at all. Battery is good, I tried a new fuse, the solenoid appears to be working fine although I haven’t taken it off and tried to replace it. I checked the fuel line and spark plug and it has brand new gas in the tank. Any ideas what might cause this problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@cknipp55 the clicking could be the solenoid. You may need to try to “hot wire” your mower to see if that is the issue. Check all wiring to and from the battery/starter as well as the safety switches. This is a new mower so there should be some kind of warranty on it. Speak with the dealer you bought it from and make use of the warranty. You paid for it so might as well use it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Charles Knipp será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 107
Duração total: 1,649
