Ir para o conteúdo principal
2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
85 Perguntas Visualizar todos
My 2020 Mac Mini not reporting correct memory
I just finished installing the 32 GB upgrade to a new Mac Mini 2020/2018. Only difficulty was re-installing the antenna cable (not the screw, the cable). Tiny fingers help.
But I do have a problem - Ordered the memory from Crucial (as I have for years…decades? For a variety of computers). Installed a single 32GB SO-DIMM in the slot closest to the center of the device and removed the 2 x4 GB SO-DIMMs.
  • But the About Mac is still reporting 2x4 GB in the 2 slots.
Rebooted a couple times, no change. Very strange. Anyone got any ideas?
BTW: Writing this on the Mac Mini, so it does power up correctly, and connects to the internet correctly.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would try resetting the systems NVRAM (PRAM) and SMC systems to see if that helps How, When, & Why to reset the PRAM & SMC on your Mac
You may need to move the SO-DIMM to the other slot.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Turns out that "sleep" is not the same as "reboot". Old habits, I rarely shut down my primary system. I did the "reboot and hold down D" and things are fine.
thanks
por
Adicionar a sua resposta
bfc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 61
