Ir para o conteúdo principal
One of the last phones of the Microsoft Lumia brand. A cheap, easy to find device that is surprisingly repairable.
2 Perguntas Visualizar todos
Microsoft Lumia 650 won't turn on but vibrates
hello
I have this Microsoft Lumia 650 that I got today.
when I try to turn it on when it's plugged in, nothing happens it just vibrates every time I press the power button and that's it.
I was thinking if that's a because of a bad battery, but I don't really know what to do with it.
any ideas?
thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Kapy where did you get it from today and what is the history. This could be a bad screen. It vibrates because it does not display anything (broken display). It could also be that a hard reset will resolve that. Try to Google hard reset Lumia 650 and follow those directions. Let us know what you find out.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thank you so much for your answer. it turned out that it was the battery's fault and it wasn't connected properly so I had to put a piece of cardboard behind it to make it actually working
por
Adicionar a sua resposta
Kapy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 593
