Ir para o conteúdo principal
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
20 Perguntas Visualizar todos
Battery not charging and gets warm
Hi question fire your regarding an apple watch screen change.
I changed mine, no problems. Seemed to work fine. But now the battery won't charge. Get the red snake when off charger, green snake when I'm charger but won't charge. Gets warm. Bought a new battery and nothing comes up as far as snake wise, the Apple logo popped up a couple times but never booted up. Gets warm then charger stopped charging, like it knows there will be Fagan's it something. It charges my wife's series three no issues. Just wondered if anyone ever came across this before and what the solution may be? I didn't think the battery would have an issue with a screen change. Doesn't seem like a connection there to me??
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
did you damage the board under the battery? did you short out any pins? hook up the battery? make sure everything looks like it should? no burnt parts? no torn cables? especially flat ribbon cables?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Derrick Brewer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 249
