Ir para o conteúdo principal
The second generation 11" iPad Pro was released in March 2020 with the model numbers A2228, A2068, A2230, and A2231.
iPad Pro 2020 replacement screen compatibility
Will a 2018 IPAD pro lcd work with a 2020 iPad Pro? Has anyone attempted this?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
2 respostas
Pergunta mais útil
No. It just won’t. The 2018’s screen is way different than the 2020’s.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks for the response.
por
It’s the same
por
Replacement laminated touch screen / LCD assembly for the iPad Pro 11" (3rd Generation & 4th Generation) - Bright, responsive, Pencil support and Retina display - everything expected from an BAQ display assembly.
Part: For iPad Pro 11 (2018) / (2020) LCD Touch Screen Black
Manufacturer: BAQ
Condition: New
Warranty: Lifetime
Compatibility:
  • Apple iPad Pro 11" 2018 / A1980, A2013, A1934, A1979
  • Apple iPad Pro 11" 2020 / A2068, A2230, A2228, A2231
Pontuação 0
1 comentário:
This response is kind of unclear... are you saying the first and second generation displays are interchangeable or are you referring to the 3rd and 4th gen?
por
Adicionar a sua resposta
King cobain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 5,614
