Ir para o conteúdo principal
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
71 Perguntas Visualizar todos
Pergunta encerrada
SSD upgrade for iPad 1
Hi,
I recently saw that the old iPad 1 3G uses a PCIe-Like conector for the "communication board", and i ask if some of you have tryed to put an PCI-e SSD drive in this slot and reassambly the unit. I imagine to put and SSD with snow leopard installed from a legacy macbook pro...unfortunately i have the wifi only versión and is not possible to me try this assumption.
thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It seems unlikely that it would work. The iPad is closer to an embedded device (like a phone) than it is to a general computing device (like a laptop or a desktop computer).
Just because the connector is close or the same doesn't mean the signaling protocols that travel over those wires are the right ones to communicate with general PCI-E devices, and for it to talk to an SSD there would need to be hard drive controller of some kind on the other end of the PCI-E bus. Since no iPad model ships with the intention of connecting to SSDs, it seems unlikely Apple would include an unnecessary chip on the logic board.
On top of all that, installing OS X on an iPad would be extraordinarily challenging. In particular, the OS is compiled for x86 and x64 processor architectures and the iPad's A4 processor is an ARM chip, so you would most likely need access the full operating system source code to recompile it for the proper architecture. Even if you got that far, there would probably be lots of hardware compatibility problems and missing drivers that would have to write and link into the OS yourself.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Bob,
You are right, even the connectors are some different in lenght between iPad communcation board and a miniPCI-e.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,020
