Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Perguntas Visualizar todos
Grey bars across screen
My IPad has grey bars across the width of the screen. Don’t know if it is significant but I tried taking a screen shot but the bars did not show up. I had to takde a photo of the screen with my iPhone. The bars get a lot darker if you tilt the screen away from you and look at it at an angle. The bars don’t obscure what is on the screen and the screen seems to work ok otherwise. It does seem to be not as bright as it once was but that may be just me. I’ve looked at a number of videos about grey bars but none of them looked like the bars on the attached photo. I’ve done the whack the back thing which didn’t do anything.
Anyone have any idea what this may be due to? I don’t want to pick up a replacement lcd panel if that is not going to fix it.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
hello George,
it looks like backlight failure. We know many reasons of that: dropping, flooding, unauthorized repair, non-genuine screen replacement, etc. I think your screen needs to be replaced - if it’s no dropped and no one has broken it before. Ff you know a little about electronics and have done something similar before, home repair can be thought of. If not, visit a good repair shop.
  • regards
Esta resposta foi útil?
Pontuação 0
It was dropped, a couple of times. I will eventually buy the parts and do the repair but it’s not bad enough to warrant spending the money yet.
thanks
Pontuação 0
Adicionar a sua resposta
George Pagliarulo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 431
