Ir para o conteúdo principal
Released in early 2008, production stopped in December 2009. Lamp used: TLPLV10.
1 Perguntas Visualizar todos
Will this projector work with a Toshiba Satellite S55-C5274 computer?
I got an adapter for the projector to hook to the computer, I tried both a USB and a HDMI adapter but still can’t get the computer screen to show on the projector screen.
Wondering if the projector is just too old.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
have you tried checking your computer's settings?
por
@hootonberg Yes, and both my brothers have tried. Thank you.
por
Adicionar um comentário
1 resposta
Solução escolhida
This projector looks like it has only a VGA input which will require that you have an adapter that converts the signal from HDMI to VGA. I have used this technique many times for other projectors without fail. You must split the audio from the HDMI if you need to send that elsewhere as well.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I have an adapter that goes from the VGA projector to the HDMI computer (that didn't work). Is there another adapter that converts the signal from HDMI to VGA?
[Audio not necessary]
por
You need an adapter that specifically converts from HDMI to VGA. I have a couple of these and they work just fine.
por
Adicionar a sua resposta
Myrna Ann será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 139
