Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
no serial number and stuck on activation
Hi there people,
got an iPhone 5c which doesn’t want activate it gets signal etc. But it just don’t activate tried plugging to iTunes etc. Still no luck. I pressed the little blue i button in the right corner realised there’s no serial number shown. Imei and the meid is shown.
would this be baseband issue? Also does any one know any fix for it. I have tried flashing the device but that didn’t work.
Any help appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Serial no is not there that means someone has repaired its NAND ic.
If serial no present but no imei then it is issue of Baseband bt in ur case serial no not present but imei is there it is clear issue of NAND Data.
Esta resposta foi útil?
Pontuação 0
1 comentário:
@iphonexpert thanks for your reply. Does that mean if use purple software to adjust the data it will work again? Because I tried flashing the phone and that finished but didn’t fix the issue? Thanks
por
Yes it will but i think people mode is not available for iPhone 5s
Pontuação 0
Adicionar a sua resposta
Rakesh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 179
