Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
795 Perguntas Visualizar todos
New SSD won’t show as an option in reinstal
I’ve replaced my old hard drive with a new Samsung SSD. I had backed up my previous drive and just did an uinbox and replaced. When I open recovery it won’t show up as an option when trying to reinstall my backup or install OSX. When I check disk utility it shows up as my internal device. What could I do? Thank you in advance for your help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Is the new drive backward compatible to SATA II (3.0 Gb/s)?
Did you first use Disk Utilities to format the drive GUID?
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank you for responding.
I did not format it in Disk Utility.
As I start to do that now and click Erase to format, I’m given many options for Format and Scheme. The default choices for both were Format: Mac OS Extended (Journaled) and Scheme: GUID Partition Map.
Would it be best to leave those?
por
what system are you trying to install
por
Adicionar a sua resposta
CampM será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 38
