Ir para o conteúdo principal
Screen jumping, glitching after installation
Replaced iPhone 11 screen but the screen is jumping and glitches after screen replacement. Had similar issue with the cracked screen so I don’t know if there was a previous issue not related to the screen. Anyone have a similar problem? Thanks
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
I can’t say I’ve had this problem before but it could be that the replacement display is also faulty. Did you unplug the battery prior to removing and reconnecting the display? I would leave it turned on for a couple of hours and see if the problem goes away, it could just be static.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Yes, I unplugged the battery. I’ve had a similar issue and agree with you that it could be a faulty screen. I’ll reach out to the ifixit team for help since I purchased it from them
por
Yes either a faulty screen or just some static, try leaving the phone turned on for a while and see if the problems carries on. If the problem continues then it sounds like a faulty digitiser.
por
I’m having this issue rn but the screen works fine when not housed properly in its case jus freely sitting while connecting an everything works like a charm an as soon as I put it in properly it starts not workin to touch at all moving on its own an jus not what it’s supposed to do
por
Adicionar a sua resposta
David Torres será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,182
