Startup issues with new High Sierra formatted SSD
I recently decided to purchase a 1TB Samsung EVO SSD to replace my older slower 1TB drive on my 2011 MBP unibody. (My old drive worked fine, but the read/write times were slow and I wanted faster performance)
I already have a smaller 500 GB SSD mounted where my Optical CD Drive used to be with a OWC Data Double Caddy. This has High Sierra installed and boots and runs fine. No issues there.
With this new SSD in place, it was detected and. I was able to successfully format the new SSD Drive to OSX High Sierra (AFPS, GUID Map) on the same MacBook.
After this ran into some problems:
1) First few times, the MacBook boots through the whole startup cycle with the grey screen, apple logo etc - I am able to login and get to my desktop, all is well with the world.
After a few tries, now when I start-up the system, I immediately get the circle hazard symbol, the computer waits a bit, and boots up through the 500GB alternate drive that I have.
This is not what I want. I want my system to booth through the new 1TB SSD as my primary drive.
I re-started the computer in recovery mode, Disk Utility detects and shows the new 1TB drive, when I run first aid on it, it detects no problems.
This time I start the laptop holding down the option key - so I can then manually choose which drive to boot from. Again when I choose the new High Sierra 1TB SSD, it shows the apple logo very briefly and then immediately shows the circle line hazard, and again boots up on the other Hard drive.
I have tried this repeatedly and it always ends up not allowing me to boot from the 1TB, and defaults to my other drive.
Does anyone know what Is wrong?
The drive is showing no errors, the OS seems to have been installed fine.
Any help would be appreciated.
Esta é uma boa pergunta?
