Macintosh PowerBook 145 Screen Issues even after recap
Hi all.
I recently got a PowerBook 145 with startup sound chime, but black/grey screen (only the backlight worked).
So I decided to recap the creen board (I used 9x 3.3uF-63V capacitors instead the 35V original ones) and the inverter board with a 47uF-16V and 33uF-16V (tantalium) caps.
The problem is that, even with this cleaning with alcohol and recap, the display doesn’t work properly… now it turns whit and shows a series of vertical lines, but nothing else.
Is the display definitely broken?
Esta é uma boa pergunta?
