Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Home button not working after screen change
I changed the screen on my phone. The original home button works fine with the original screen. It does not work with replacement. When i power it on it does not pop the unable to activate home button etc warning at all. in settings i can go into fingerprint section and select add print, but it does not register. home button does not work. Is it the home button cable on the replacement screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The home button flex cable from the screen to the logic board will have a small tear. This usually happens at the 90 degree bend and might be hard to see without magnification. Your only solution is to replace the screen.
Esta resposta foi útil?
Pontuação 1
1 comentário:
it does seem as if it is the screen, as i stated the button is fine, so is the phone, as it works fine with the original broken screen.
por
Pergunta mais útil
I have had this issue in the past. The home button on the iphone 7&8 are not a actual “button”, they are just touch sensors. The only real way to keep your home button working is to switch over the original when doing a screen replacement, if not you will loose all functionality of the button. I replaced a screen on a 7 and switched over the home button, but the button didn’t work at all. I switched over the metal heat shield that has the original home button flex cable into the new screen and it started working fine. I also made sure that the bracket and the button itself were all aligned and tightened. Hope this helps, good luck!
Pontuação 1
2 comentários:
Also you may have damaged the extension flex cable and the flex cable on the home button. Check for any small tears, they are extremely fragile.
por
As i stated, the button works fine with the original broken screen. it is not possible to use the home button cable from the old screen as far as i know.
por
Adicionar a sua resposta
sam caspian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 89
