Ir para o conteúdo principal
O Dell Inspiron 14R-5437 é um notebook substituto de desktop feito para durar. Com uma bateria de reposição de 6 células e um processador Intel Core i3 de quarta geração de baixo consumo de energia, o Inspiron 14R-5437 tem autonomia para funcionar por quase dez horas.
Wrired Upload Speed Issues
Hi,
I have issue with low download speeds. I have 40Mbit download current speed, my customer is just donwloading at about 4Mbit speed however. On the opposite side, transfer speed is pushed to the limit. Utilizing Transmission customer. I have 25% of the record downloaded and customer says 100% accessibility, so there ought to be no motivation to not go max throttle. I have set open port and made each setting to make it quick, added not many public trackers. There is a lot of friends, which have all the information, yet customer is nearly not downloading from them. It is downloading from others all things considered.
Proportion is going up to 2.0. Where could be the issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Please kindly check out these methods for a possible fix.
https://superuser.com/questions/1233477/...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
KyleFoleyk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 337
